red-thumb
Not too sure where the source of your VDB code numbers come from - maybe you could clarify this point for me - I have only seen information on the Ford Refuse truck in the Matchbox Regular Wheels 1-75 and the Missing, Previously-Catalogued RW 1-75 Regular Wheels forums. As far as I can remember none of these referred to the colour of the plastic insert.
In terms of plastic inserts the colours I have are:
The standard green (or turquoise to my eyes!)
Clear
Off white/light grey ( This is on a model that may hve suffered solvent or heat damage so may not be a factory original colour)
Yellowy green (This may be the same as the amber colour you listed)
Violet/Light purple
The off white/light grey insert is solid in colour whilst all the others are translucent i.e. see through
With regard to the model with the narrower insert this refers to the width across the insert when viewed through the front windscreen of the cab - it is not easy to measure - I would estimate it at between 0.5 and 1 mm.
Since I last posted I have found that some of my models have a number cast in the metal below the plastic insert - either 2, 3 or 4
These are not easy to see and may require the use of a magnifying glass and a good light source
Other slight variations include the letter on the inside roof of the cab glazing and the presence or absence of what looks like a lower case letter j or reversed number 1 on the inside surface of the top of the metal frame of the container
To see this you will need to tip up the back of the model and look in through the rectangular opening of the metal frame.
This should bring in to view the lower surface of the metal frame that is normally hidden from sight when the container is in the closed position and allow you see whether the model has the j or number 1 present
One of my models has a mixture of thin and thick wheels - I posted a photo of it in the Missing, Previously-Catalogued RW 1-75 Regular Wheels forum on Friday 13th April 2018. To see it just click on
download/file.php?id=35521
With regards to the casting pip it is on the underneath of the metal container frame - approximately halfway across as per the attached photo - see centre of black circle
Happy Collecting
Sebastian
