Page 1 of 4
				6c Euclid Dump truck
				Posted: Sat Sep 23, 2017 7:23 am
				The listing in the NAMC’s “Catalog of all Series Matchbox Models” (second edition) is extremely difficult to interpret, but does not seem to contain any new variations.
None of AIM's “1-75 Series Regular Wheels” catalogue (second printing, 1983), Stannard, Houghton, or Leake ("Concise Catalogue of 75 Series Matchbox Toys by Lesney" (4th edition, reprinted 2006)) lists any variation not already catalogued by Nick, although Stannard's variation code 6c-9 and.Houghton's identical variation code 6c-15 both point to Nick's variation code 15 being incorrect: the rear wheel entry should read "12.5 x 4.5 twin wheel unit as M9" instead of just "12.5 x 45".
U.K. Matchbox examined the model in vol. 8 no. 2 ((Jun. '84) p46 but did not list any new variations.
				Re: 6c Euclid Dump truck
				Posted: Sat Sep 23, 2017 4:37 pm
				Hello Hugh and all,
I believe the order of the first 6 codes and the second 6 codes should be swapped over.
The detailed front wheel with the ring of lug nuts came before the detailed front wheels without the lug nuts.
This is best evidenced by their use on the M9 Cooper Jarrett paired with the base plate with inverted commas introduced in mid 1962.
I also note Nick mentions in the description and lists from code 16 on, the regular bpw as 12.5 x 45 but all mine are 12.5 x 40 as per Stannard code 10 onward. It seems this error is repeated in Houghtons also.
Note to Hugh, in your post above the 4.5 should read 45 ( tread) in second last line.
				Posted: Sat Sep 23, 2017 5:24 pm
				yellowfoden wrote:Note to Hugh, in your post above the 4.5 should read 45 ( tread) in second last line.
Corrected! Thank you!
				Posted: Thu Oct 12, 2017 8:41 am
				yellow and dark yellow, pretty much the same colours as the 6b. Code 14 yellow, code 19 dark yellow.
				Posted: Thu Dec 21, 2017 8:54 am
				DrJeep wrote:yellow and dark yellow, pretty much the same colours as the 6b. Code 14 yellow, code 19 dark yellow.
Hi Glenn, I can confirm your yellow and dark yellow variation. I am enclosing a photo from July 2012 with comparison of yellow shades. I will upgrade a list with new 6c variations. I think that there are 8 variations of the tipper (up till now 6 mentioned).
				Posted: Thu Dec 21, 2017 1:35 pm
				Hello Hugh, Antonin, Glenn and all,
Santa started his deliveries in our part of the world early with a new variation for the 6c Euclid Tipper that has now joined our fleet.
The specs for this one are as follows:
A type tipper
Gap under A
E and part N missing along with thin crossmember
Thin step right side
No step left
All this equals
Body 2, tipper 2, no trim
12.5 x 40 BPW
Coded as 20a using the current table from Nick
The added bonus with this model is that it has light colour cab and dark colour tipper which are currently not differentiated within the codes.
Antonin, thanks for adding the colour comparison pic above, this was the one I was referring to in the other thread started by John.
				Posted: Thu Dec 21, 2017 7:54 pm
				Hi Bert and Antonin
Very nice 6c from Bert - an unlisted variation and in two colours too! I’m confused by the different tippers and body combinations, though perhaps it will all be clearer when Antonin lists the 8 tipper types. I think I’d vaguely assumed that there were two separate tipper moulds, distinguished by A and B, and then the different tipper codes show wear and subsequent repair to the moulds. But I’m probably wrong!
Glenn
				Posted: Fri Dec 22, 2017 4:48 am
				I think you are quite right Dr. Jeep. Possibly though, two "A" paired molds and a second set of paired "B" molds might have been needed for such a high production popular selling Toy that lasted in the Lesney lineup for 5 years?
     If no one minds Hugh, perhaps the newer Post which was labeled "New 6C Variation" should be moved here because our discussion there involves one of the 2 "new" Tipper types that Antonin will be introducing here in his new chart I am sure. With 2 or 3 of us having them in our collections already, there will be new confirmed variations immediately on this popular Dumper. Cheers!   Kwakers
				Posted: Fri Dec 22, 2017 11:35 am
				kwakers wrote:If no one minds Hugh, perhaps the newer Post which was labeled "New 6C Variation" should be moved here because our discussion there involves one of the 2 "new" Tipper types that Antonin will be introducing here in his new chart I am sure. With 2 or 3 of us having them in our collections already, there will be new confirmed variations immediately on this popular Dumper. Cheers!   Kwakers
I've had a look at this, Dick. The problem is that the two discussions will then becime interleaved since the original posting timestamp is preserved when merging threads.
For the time being, I think we're just going to have to make do with links:
Unlisted 6c variation, and
6c Euclid Dump Truck.
What would be useful would be if, when the other discussions have run their course, summaries could be posted here.
				Posted: Sat Dec 23, 2017 7:53 am
				I am enclosing an unlisted variation of the tipper base. The last mentioned variation is with letter "B" with bar bellow and with "ENGLAND" on the raised platform.
I have the variation with letter "B" with bar bellow and with "ENGLAND" on the flat platform.
The next variation should be the same but without "E" in the word "ENGLAND", but I can not find it now. Sorry I have no photo, only a short notice. I do not remember if I have it or if I have seen it somewhere.
