51c AEC 8 whell tipper ?
Posted: Sat Jan 10, 2015 6:22 pm
by mike
When searching for the correct code!
I noticed these differences.
Has been this already discussed?
See photos.
Cheers Mike
Re: 51c AEC 8 whell tipper ?
Posted: Sat Jan 10, 2015 6:32 pm
Hi Mike, the hydrosleeves are the same but fitted in different ways iirc. Have a look from above.
Posted: Sat Jan 10, 2015 6:39 pm
by mike
johnboy wrote:Hi Mike, the hydrosleeves are the same but fitted in different ways iirc. Have a look from above.
Thank you Johnboy.
But the numbers 1 + 2 at the bottom tipper?
Posted: Sat Jan 10, 2015 7:56 pm
These are die numbers, They make it easier to find out which dies need repairing / replacing.
Posted: Sat Jan 10, 2015 8:01 pm
by mike
Posted: Sat Jan 10, 2015 8:15 pm
Mike If the casting is defective or there is another problem with it, the number on the casting (1,2 etc) will match the number on the die that was used. So at the factory, the workers knew which die needed inspection. There were numerous dies and without a number it would be hard to find the defective die.
Posted: Sat Jan 10, 2015 8:55 pm
by mike
Many thanks Johnboy.
You are a great help.
Please for a further information.
I compare the models with Nick's photos on his website.
(Baseplat thicker on left / on right)
I see no difference in my models?
Cheers Mike
Posted: Wed Jan 14, 2015 12:29 pm
by AJR
The earlier Hoveringham Foden looks to have the same body as this later AEC but when I decided to do my own code 3 Hoveringham AEC, I found that the earlier body doesn't fit. It isn't far out but it is completely different.
Posted: Wed Jan 14, 2015 4:26 pm
by mike
I'm looking forward to more information on this topic.
Prost Mike & Nico
Posted: Wed Jan 14, 2015 9:29 pm
AJR wrote:The earlier Hoveringham Foden looks to have the same body as this later AEC but when I decided to do my own code 3 Hoveringham AEC, I found that the earlier body doesn't fit. It isn't far out but it is completely different.
Yes, they are pretty much the same size but completly different. Still, where there is a will there is a way:
