17b Removals Van
Posted: Thu Dec 29, 2016 12:32 pm
The NAMC’s “Catalog of all Series Matchbox Models” (second edition) appears to contain an error since the details of variation code 17-1H are identical to those of variation code 17-1I. (It should be noted that NAMC catalogues 17a and 17b as a single model coded 17-1.)
The AIM's “1-75 Series Regular Wheels” catalogue (second printing, 1983) lists a plausible crossover as variation 17-2d: green, GPW, r/a, plain white lettered decal (see below).
Neither Stannard nor Houghton lists any variations not already catalogued by Nick.
U.K. Matchbox examined the model in vol. 1 no. 6 (Aug. '77) p90, and then again in vol. 6 no. 1 (Apr. '82) p22, with a follow-up in vol. 6 no. 2 (Jun. '82) p64. A variation, 17B-8, which is probably the same as AIM's variation code 17-2d was identified: green, GPW, d/h, r/a, no. 17 cast, plain white lettered decal, hand-applied trim. This crosses so many timelines, it is unclear where it would fit in Nick's variation table!
One question: Nick's listing has both 8.5 and 9 mm diameter MW. Do these actually reflect numbered and unnumbered wheels respectively?
