How to clean?
Posted: Mon Dec 21, 2020 1:20 pm
by Dinkied
Hi,
I have a breakdown lorry what has been out of its box for a while and accumulated a thin layer of settled dust.Iwas thinking of a cotton bud with tepid water. What would you recommend as the best method.
Thanks
Re: How to clean?
Posted: Mon Dec 21, 2020 1:47 pm
Using a half inch decorators' brush I first brush off all the loose dust. I then use soft supple artists paint brushes to carry on removing the loose stuff but the smaller brushes get into small areas and corners.
If I have to use liquids, it will be nothing stronger than scilicon based house polish in the spray can, sprayed on a flat surface such as an old bathroom wall tile and dip the brush into the polish and apply to the model. Follow up with clean dry brushes and or a clean dry duster cloth to buff up where you can.
I know some collectors do use warm water with a touch of washing up liquid but so far I have not used this method.
Re: How to clean?
Posted: Mon Dec 21, 2020 2:16 pm
by Diecastmolester
I use warm water and washing up liquid.
Then rinse with running water, dab the excess water off with a kitchen towel and put it on the heater radiator to dry.
Avoid this method if the models have paper stickers, though.
Re: How to clean?
Posted: Mon Dec 21, 2020 3:29 pm
by Dinkied
Thanks for the replies. I will invest in a couple of artist brushes.
Re: How to clean?
Posted: Mon Dec 21, 2020 4:46 pm
I wash models as above. So long as all parts are secure to the model, I use a hair dryer on a warm setting to remove moisture that can't be dabbed off
Re: How to clean?
Posted: Mon Dec 21, 2020 5:17 pm
by Squid
Ive been lucky in that all the models I've cleaned have needed nothing more than water and mild liquid dish soap. I apply that mixture with a Q-Tip or a piece of old T-shirt. Decades ago, I'd use a paint brush, but I noticed that particular brush put fine marks in the paint. For really dirty models, I might be tempted to use my air compressor cranked down to about 10 PSi.
I also wouldn't use soap and water on labels or decals that I wish to keep intact.
Re: How to clean?
Posted: Wed Dec 23, 2020 8:53 am
by Diecastmolester
I have found that the old original waterslide transfers survive the cleaning with soapy water.
They must be of a similar material/glue that was used on bicycle frames, probably even the same.
Replacement decals don't and like you say, water shouldn't even be near paper labels.
Re: How to clean?
Posted: Thu Dec 24, 2020 3:34 am
I seen some people use household alcohol to clean their models. Warning, alcohol will strip the ink right off the decal film and leave you with a blank decal (older decals are especially sensitive to alcohol).
Re: How to clean?
Posted: Thu Dec 24, 2020 8:30 am
Tinman wrote:I seen some people use household alcohol to clean their models.
I was also thinking about solvents, especially for e.g. adhesive residues.
Two important considerations: I) compatibility with the paint/decals (you don't want it stripping paint/ink or resulting in discolouration), and ii) purity (you don't want the solvent evaporating only to leave behind an insoluble residue).
Re: How to clean?
Posted: Thu Dec 24, 2020 3:52 pm
by Squid
For removal of adhesive residue, I always try lighter fluid (such as Ronsonol) first. It usually does a bang-up job, and I've yet to have it damage paint or plastic.
