Casting #63
Posted: Fri Oct 25, 2013 2:32 pm
63a Service Ambulance Ford 3 Ton 4x4, issued 1959, length 63mm, box types B-C and D.
63b "Foamite" Crash Tender (Alvis), issued 1963, length 63mm, Box type E.
63c Dodge Crane Truck, issued 1968, length 76mm, box type F.
63a 10 x 24 tread bpw.
63a the harder to find 11 x 36 tread bpw.
The 1st casting with D Crimped axles and no hole in the base, both type of bases.
63b with the Silver Foam Hose.
63b with the Gold Foam Hose, under the plastic parts.
The Red Hook model single strand hook, but the Red hook also comes with a double strand hook.
The Yellow Hook Model only comes as single strand hook.
I will put this box in as it belongs to the 63c model, the boxes when you look at the face model and turn it 180 degrees the picture is the same upright, but on this box the reverse side through 180 degrees the model appears upside down as shown, I will also put this on the Box forum.
