Missing Y4-2 firemen
Posted: Sat Jul 27, 2019 10:48 am
While putting some of my MOY's in order I came across my Y4-2 Shand Mason, that had 2 crew members that were AWOL, as is often the case on this model, that and the famous headless firemen. I know that replacements are available, however being the DIYer that i am, I thought i would have a go at making my own.
A couple members of the crew of the white horse team had gone missing
a crew member from the black horse crew as borrowed and along with some thermo plastic pellets and a cup of hot water I set to work
the pellets were heated and then using the borrowed crewman I created a simple two part mold by pressing the firemen halfway into one side, allowing it to cool thouroughly and harden and then pressing the hot thermo plastic onto the other side, to create the second half of the mold. A small relief hole was drilled in one of the mold halves to let excess resin escape and some alignment pins were made by pressing a ballpoint peen into the first mold half while it was still pliable. After fully cooling the mold halves were separated and the original fireman removed from the mold.
I then filled each of the mold halves with my casting resin, which in this case was JB Weld epoxy.
The halves were then pressed together, clamped and allow to cure.
After curring the mold was placed in a bit of warm (not boiling hot) water to help open it et voila the missing fireman had magically appeared
with just a bit of trimming and a a wee bit of filing he was ready to be painted up
a pin was added for the driver and a hole drilled for the firemen fixing points
All done, with the crew complete once again.
zBret
zBret
