#33 error
Posted: Wed Feb 13, 2019 5:12 pm
Interesting cheap eBay win
Rivets are good and the roof rivet is unspun
Solid wheels numbered 2 and 20 front. 2 and 29 rear
Tow guide base with an unusual hole??
I'll have it at Brentwood and Sandown if anyone wants a better look
Re: #33 error
Posted: Wed Feb 13, 2019 6:01 pm
Are there not any letters with those numbers Reg, prefix or sufix.
Re: #33 error
Posted: Wed Feb 13, 2019 6:44 pm
Not that I can see
Re: #33 error
Posted: Wed Feb 13, 2019 6:51 pm
by MOKOSEX
The hole maybe caused by a die fault known as a broken ejector,if an ejector breaks forward you get a hole,if it bends or breaks in a back position you get a column of metal,if someone has a loose base you could see if it lines up with an ejector,working ejectors leave a ring level with the casting surface . :D
dave
Re: #33 error
Posted: Wed Feb 13, 2019 8:07 pm
MOKOSEX wrote:The hole maybe caused by a die fault known as a broken ejector,if an ejector breaks forward you get a hole,if it bends or breaks in a back position you get a column of metal,if someone has a loose base you could see if it lines up with an ejector,working ejectors leave a ring level with the casting surface . :D
dave
Good idea! (Haven't we seem something very similar before?)
What is interesting is that, if it is the result of a stuck ejector, someone spotted the hole in the baseplate but, even so, decided to assemble the model albeit without either interior or windows, suggesting that it could be some kind of trial piece.
Re: #33 error
Posted: Wed Feb 13, 2019 8:37 pm
hadn't thought of it as a trial piece, could that explain the lack of letters on the whees ?
I have noticed the raised part of the wheel circumferance is narrower than the other one of these I have
Re: #33 error
Posted: Wed Feb 13, 2019 9:02 pm
fixer wrote:hadn't thought of it as a trial piece, could that explain the lack of letters on the whees ?
That is a very plausable status for the model because with only numbers moulded on the wheels it takes production (or at least the moulding date for the wheels on this example), into early and mid 1969, with the letter 'A' Prefix coming during late 1969.
Re: #33 error
Posted: Wed Feb 13, 2019 9:22 pm
Great model Reg, looks like the rivet I can see holding the wheel strip is not pressed either or is it just the angle of the picture.
Re: #33 error
Posted: Wed Feb 13, 2019 10:12 pm
Idris wrote:Haven't we seem something very similar before?
Found it!
Re: #33 error
Posted: Thu Feb 14, 2019 12:09 am
J the wheel strip is spun on both points
I've checked with my other one of these and it seems to have a chisel cut rivet, unfortunately all my other 33s are packed away
The ejector theory is correct in my opinion judging by the mark on the opposite side ...good call Dave
