Centurion Tank (651)
Posted: Wed Jan 30, 2019 7:08 pm
by kevspeed
Hi all,any hints on replacing the tracks on this model?,there doesnt look to be enough room between the front wheels to slide it past
Re: Centurion Tank (651)
Posted: Thu Jan 31, 2019 2:11 am
by RSSierra
Hi
Only two options, either drill the rivets, remove the base and fit tracks, or cut the tracks feed through and superglue the ends back together. Ideally with the later option you also glue some flexible "tape" or similar across the join on the inside of the track to support the glue and strengthen the join.
The second option looks better and won't devalue the model.
Cheers
Dave
Posted: Thu Jan 31, 2019 5:25 pm
by kevspeed
Hmmmmm,something to think about
