Spot the Difference = why are these two pre-pros?
Posted: Sat Jun 09, 2018 12:51 pm
by matchboxuk
These two models are both pre-pros. How quickly can you decide why?
Re: Spot the Difference = why are these two pre-pros?
Posted: Sat Jun 09, 2018 1:06 pm
matchboxuk wrote:How quickly can you decide why?
Very (but I won't spoil the fun for everyone else).
Posted: Sat Jun 09, 2018 1:14 pm
The Zodiac was easy but the Ford tractor took a little longer. Really interesting - thank you very much for showing these.
Posted: Sat Jun 09, 2018 3:29 pm
by Fox
As a newbie I would say something about the hood or inside it fof the Zodiac.
Posted: Sat Jun 09, 2018 10:14 pm
by MatchboxFreak
Thank you for sharing. They are beauties!
The Zodiac wheels immediately jumped out.
Interesting to see the 39c Ford Tractor with the white steering wheel. I would have expected a pre pro 39c to also have the 7mm tall exhaust similar to the early casting. Does the pre pro casting have the thin tow hook?
Posted: Sun Jun 10, 2018 8:17 am
MatchboxFreak wrote:I would have expected a pre pro 39c to also have the 7mm tall exhaust similar to the early casting.
Good point!
Posted: Sun Jun 10, 2018 9:13 am
by matchboxuk
MatchboxFreak wrote:Thank you for sharing. They are beauties!
You are absolutely right. This version has a thick tow hook and a short stack so it could not have been produced before general production started. It is securely fixed and is identical in shape so I have no idea why this would have been produced.
Thanks for spotting.
Posted: Sun Jun 10, 2018 9:49 pm
by Sebastian10
matchboxuk
I would have some doubts about the tractor being pre production solely based on having a white steering wheel. Last year I bought an early version of the yellow/blue tractor with the long exhaust stack and a broken but thin tow hook - it was in a job lot for only a few pounds.
The steering wheel was all but gone but I remembered that I had an all blue version that I had bought for 25p about a decade earlier - this model was playworn but still had a black steering wheel in good condition. After digging out this model I gently pulled its steering wheel by hand and it seemed to be absoutely stuck fast. However I went to the trusty tool box and dug out a pair of fine long nose pliers and used these to grip the top of the steering wheel shaft just below the spokes - the steering wheel started to move upwards and with a bit of effort came free - it was simply a push fit albeit it needed some determination to shift.
Using the same method I removed the remains of the steering wheel on the long exhaust tractor and simply pushed the 'new' steering wheel into place.
I have seen a few of the short exhaust models fitted with yellow steering wheels for sale at inflated prices (One at nearly £2000!) but given how easy it is to swap steering wheels I would not risk buying something that I could probably make up using spares from a reproduction parts catalogue.
Last year I managed to buy 3 of the long exhaust tractors and 3 tractors with the larger front wheels but all unboxed so I began to look for a standard model with a good box at a competitive price. I got one online and was pleasantly surprised to find that the tractor was fitted with the usual black steering wheel but of much larger diameter. Unfortunately I did not save the online picture properly and all I have at present is the tiny picture shown - hopefully though this will show the larger diameter of the steering wheel.
Happy Collecting
Sebastian
