Dodge Wreck Truck Project
Posted: Sun Aug 06, 2017 1:35 pm
by Tito
Hi All:
Working on doing a little custom paint job for a #13 Dodge wrecker. I want to install a new hook, but not sure about how remove the old remnants. Anyone attempt this? Please share your knowledge.
Tito
Re: Dodge Wreck Truck Project
Posted: Sun Aug 06, 2017 8:18 pm
Before any preperation like the primer stage you seem to have done, I would heat it up over a candle or some other small flame and when quite soft just pull it away from it's fixings. Now the model is primered, cut through the remains with a sharp modelling knife and tease the Two halves out.
Posted: Mon Aug 07, 2017 12:31 am
GHOSTHUNTER wrote:Before any preperation like the primer stage you seem to have done, I would heat it up over a candle or some other small flame and when quite soft just pull it away from it's fixings. Now the model is primered, cut through the remains with a sharp modelling knife and tease the Two halves out.
That's one way, be careful not to bend the boom tips outward. I'd just put a cut-off wheel on the Dremel and cut through the center of the plastic. Here what it looks like without the hook (two little pips or bumps hold the hook on). The hooks are installed by placing the wide top portion directly over the boom tip and pulling straight down until it locks into place on the pips.
Posted: Mon Aug 07, 2017 11:17 am
by Tito
Step one -- removal -- completed. Thanks Ghosty. Used an X-acto knife. Onto Step two. Thanks for the tip Tinman. I need to find a hook.
Posted: Mon Aug 07, 2017 12:03 pm
by zBret
Heres one I made myself using a bit of electrical wire and jb weld epoxy
zBret
Posted: Mon Aug 07, 2017 4:56 pm
The hooks are made in red and yellow and available from the usual replacement parts sources.
Posted: Tue Aug 08, 2017 6:51 am
by Tito
I'm going to see if I can cannibalize an existing truck for the hook. The shipping charges on parts are rather steep to the U.S.
Posted: Tue Aug 08, 2017 11:54 pm
ToyResto is back in business. Ships within the USA for a reasonable rate.
https://www.toyresto.com/shop/index.php ... 88fc414066
Posted: Wed Aug 09, 2017 3:39 pm
by Tito
Thanks for the link. Sadly, I already ordered from an e-bay supplier. I am familiar with Toy Resto. Glad they are back. Will keep them in mind.
Tito
Posted: Mon Oct 09, 2017 4:49 am
That's a really great looking hand made hook.
zBret
