68b open axle base, two casting variations, 1 unlisted
Posted: Thu Oct 10, 2013 10:37 pm
I brought this up years back on a USA based forum but these base casting differences are still being overlooked in most guides. The early and first base casting (and the one found on the first issued model with the turquoise paint) has thin axle supports that are 1mm wide and 8.5mm long. The open rectangles in the base are small. This base carried over into the orange paint variations.
Before the axles were closed, another base modification was made. The supports were widened to 1.5mm and length was increased to 9.5mm. The open rectangles were made larger as well. So the base (or body casting which includes the base) had a total of four modifications (not the three that are commonly cataloged).
I suspect most people simply over look the two different open axle bases. The second modification may or may not be hard to find as there has never been much discussion about it. I suspect the second modification to the 1.5mm wide supports was short lived before the axles were closed.
