Early 80's Lesney England missing from lists?
Posted: Mon Feb 01, 2016 6:16 pm
by TOYRFIC
Can we start to include variations of the early 80's Lesney England base models here in the SF casting show?
I noticed that the header lists of models shown usually don't have all examples listed, i.e. #44 Chevy 4x4 van, #56 Peterbilt Tanker, #71 '62 Corvette.
Re: Early 80's Lesney England missing from lists?
Posted: Mon Feb 01, 2016 9:16 pm
Jason I have no objection if you want to post some images. 1981 was agreed as a cut off date for the casting show, however should you have some other 1980's 'Made in England' baseplate models that are not listed here feel free to add some images.
No Macau bases please!!
Posted: Mon Feb 01, 2016 9:55 pm
Additional to what "Motorman" says, we do have a 'Modern Matchbox' models section, if you wanted to add some stuff in there.
Posted: Tue Feb 02, 2016 12:02 am
by Rob
1982 is the year that England bases are generally associated with being manufactured up to. The 3 models Jason uses for his examples do have allocated reference numbers for them which are shown on Christians site.
4x4 Chevy Van issued 1982 in USA is 44d
Peterbilt Tanker issued 1982 USA is 56d
'62 Corvette issued 1982 USA is 71d
So my thinking is that any such England base models should just be tagged on to the end of their respective number listing that we already have, that way it makes accessing them fast and efficient as opposed to hunting through loads of posts.
Posted: Tue Feb 02, 2016 1:36 am
by TOYRFIC
motorman wrote:Jason I have no objection if you want to post some images. 1981 was agreed as a cut off date for the casting show, however should you have some other 1980's 'Made in England' baseplate models that are not listed here feel free to add some images.
Oh no, I would never post pictures of Macau base models here! But, they are just as friendly, fun, and cuddly to collect as much as the England base varis!
Posted: Tue Feb 02, 2016 2:43 am
by Miller
TOYRFIC wrote:Oh no, I would never post pictures of Macau base models here! But, they are just as friendly, fun, and cuddly to collect as much as the England base varis!
Jehova, Jehova
Posted: Tue Feb 02, 2016 8:22 pm
Rob wrote:1982 is the year that England bases are generally associated with being manufactured up to. The 3 models Jason uses for his examples do have allocated reference numbers for them which are shown on Christians site.
Agreed Rob, I have added each model to the appropriate model number in the casting show. I have coded them using Nicks codes for consistency rather than Charlie's, however I appreciate that some collectors will only use Macks variation codes.
Posted: Tue Feb 02, 2016 8:25 pm
TOYRFIC wrote:Can we start to include variations of the early 80's Lesney England base models here in the SF casting show?
Jason I have added each of the above models to its appropriate model number within the SF casting show. If you have some images to post then please add them under each respective number. Thanks
Posted: Tue Feb 02, 2016 8:27 pm
TOYRFIC wrote:motorman wrote:Jason I have no objection if you want to post some images. 1981 was agreed as a cut off date for the casting show, however should you have some other 1980's 'Made in England' baseplate models that are not listed here feel free to add some images.
I treat them with the same regard as their Eastern European cousins
Posted: Tue Feb 02, 2016 11:40 pm
by Rob
motorman wrote:Rob wrote:1982 is the year that England bases are generally associated with being manufactured up to. The 3 models Jason uses for his examples do have allocated reference numbers for them which are shown on Christians site.
Thanks Alex, yes, I use Macks coding as it says which SF model was issued first, second, third etc in each number category. It also keeps the SF separate from the Regs as well, rather than following on from them in one listing, which helps collectors who just collect SF, and I guess was Macks reasoning.
