#14 Zodiac Mk3 Estate
Posted: Sun Jan 17, 2016 7:37 pm
Only 2 colours that I have come across usually in metallic blue and a less common light blue again with various coloured interiors one noticeable difference is to the jeweled headlights the one's which I think are earlier are larger and have rings cast around them the second type are a smaller jewel set in a single oval shaped surrounding its this shape that appears to have been adapted for the Flyers issue with the headlights cast in place
Re: #14 Zodiac Mk3 Estate
Posted: Sun Jan 17, 2016 8:00 pm
by jeff f
hi, great model ,allso comes in gold, and in the flyers range in yellow, and of course police finish i allso seen a met green one, shame the tailgate and bonnets go missing on so many
Posted: Sun Jan 17, 2016 8:03 pm
by ogedei2
Nice comparison pic sunshine :)
Think it is the earliest, Ive only seen the 2 bigger lights version with rough tyres
Posted: Sun Jan 17, 2016 8:43 pm
The larger separate jewelled headlamp version is the earlier of the Two. Not sure when this change took place because the smaller paired jewlled set were available at the time the Zodiac was issued and it must just be down to an attempt for easier production.
Here is a smooth tyred version with the Orange interior.
Orange interior.jpg (54.39 KiB) Viewed 1613 times
Posted: Sun Jan 17, 2016 10:13 pm
personally i think the larger lights look much better and more to scale
Jeff you are correct about the other colours these are part of the Flyers range which we will come to later
i've not seen a gold Impy one do you have one ?
Posted: Sun Jan 17, 2016 10:20 pm
I would just like to say that I am loving this Lone Star mini Forum and am almost considering starting collecting these wonderful models. Thanks Reg for all your hard work in getting this of the ground. :D
Posted: Sun Jan 17, 2016 11:30 pm
motorman wrote:I would just like to say that I am loving this Lone Star mini Forum and am almost considering starting collecting these wonderful models. Thanks Reg for all your hard work in getting this of the ground. :D
come to the dark side Luke together we can rule the universe (with the help of Ghosty and some of the others so long as it's ok with Hugh :D )
