New 8a variation?
Posted: Mon Nov 02, 2015 12:06 pm
by eburak
I am cataloging my models regarding to Nick's guide.
I have two 8a models. One is yellow with type B engine (closed at rear only), with yellow driver and black hat. There is no such kind of variation on Nick's guide. There are 3 possibilities.
1- This model is repainted/not genuine
2- This model manufactured in early stages without painting the driver to red (unlikely because trim is silver)
3- Model manufactered and painted at later stages with an older cast.
Here is the discussion about authenticity of model in the other topic.
viewtopic.php?f=11&t=4305&p=46737#p46737
There are some other pictures in the link. Here is a picture showing engine type.
And also the other 8a model fits with code 6 on Nick's guide. But there is a hole/gap behind drivers legs.
Do any other collector have this kind of models?
Regards,
Burak
Re: New 8a variation?
Posted: Fri Nov 06, 2015 11:52 am
by eburak
There is not much interest to this topic. I was surprised when I find a new variation but I think there are a lot more.
I am keep checking my models regarding to Nick's guide. I am at 20 yet. Here are the list of some more not mentioned variations:
1- 8a Tractor : Yellow body, yellow driver with black hat, silver grill, type B engine(closed at rear only)
2 - 8a Tractor: Orange body. Same as code 6. Have hole behind the drivers leg.
3- 9b Dennis Fire Escape: Same as code 6 but flat head axles (need confirmation)
4- 10c Sugar Container Truck: Same as code 18 but with body line
5- 17c Austin Taxi Cab: Same as code 1 but light/pale gray interior(not sure because not have any other model to compare)
6- 19d Lotus Racing Car: Orange body. Same as code 10 or 11 but "with extension ring and mixed text"
7- 19d Lotus Racing Car: Green body with decals. Same as code 2 or 3 but "without extension ring and small text"
And also I found another example of new code 5 18b CAT bulldoser with light/lemon yellow doser blades.
I can put some pictures later if anyone interests. Will continue to check my other models. There are 55 series more to check.
Regards,
Burak
Posted: Fri Nov 06, 2015 1:15 pm
Yes please, pictures, pictures and more pictures always welcome.
Posted: Fri Nov 06, 2015 3:21 pm
by eburak
OK. I will try to post some pictures next week.
Posted: Fri Nov 06, 2015 5:27 pm
by eburak
Find a 24 c fits to code 7 with an ejector ring between the boot hinges. Not mentioned on Nick's guide but fits with code 9 on Houghton's guide.
By the way not sure where to post pictures. To this topic or different topics for each? Or under the casting show?
Posted: Fri Nov 06, 2015 7:03 pm
on questions like these it would be best to keep them seperate and always pictures they speak more than words
Ghosty i think your the man for the #24c question
Posted: Fri Nov 06, 2015 7:32 pm
Thank's Reg. I believe the boot ejector ring (circle), has been discussed somewhere on the forum, but can not find it at the moment (Hugh is good at this :D ), but Nick certainly does not mention it in the 'Code Listing' for #24c.
According to my own listing for #24c, it appears on models introduced during 1969, so these are examples with all the casting modifications...
Large base rivet head.
Low boot-hinge cut-outs.
Full towing facility at the front.
Patent number on baseplate.
Rear wheel-arch inner braces.
Cherry Red body colour.
Matt Black baseplate colour.
Posted: Sat Nov 07, 2015 12:56 pm
GHOSTHUNTER wrote:Thank's Reg. I believe the boot ejector ring (circle), has been discussed somewhere on the forum, but can not find it at the moment (Hugh is good at this :D )...
I think it was discussed in depth on Lefora, but there is further discussion here.
Posted: Sat Nov 07, 2015 1:53 pm
Thank you Hugh, I knew you could do it :D
Posted: Thu Nov 12, 2015 4:14 pm
by eburak
eburak wrote:There is not much interest to this topic. I was surprised when I find a new variation but I think there are a lot more.
Regards,
Burak
I will start to post pictures. I am wrong about 7)19 d green Lotus. It has extension ring.
Still curiously waiting comments about 8a models from veteran collectors.
Burak
