Pickfords Shutter Door
Posted: Sat Aug 29, 2015 1:37 pm
It spoils the model if the shutter door is missing on these vans, so if you've got a nice van and you want to complete it, fitting a door is quite straight forward and only takes a few minutes. I had a genuine door from a beater which I used for this and I used a pick to help. (Take it carefully and you won't scratch the van with the pick, you may be able to use a finger instead but I couldn't).
Re: Pickfords Shutter Door
Posted: Sat Aug 29, 2015 1:43 pm
That seems like a lot of work. The bases generally pop right off the model and go back on as easily.
Posted: Sat Aug 29, 2015 1:52 pm
Tinman wrote:That seems like a lot of work. The bases generally pop right off the model and go back on as easily.
True, but this one is a two-line model and I wasn't taking the chance. It only takes a few minutes and I rest easy knowing the base is left intact.
Posted: Sat Aug 29, 2015 4:55 pm
is that the one we spoke about a while ago at Pottersbar
nicely done JB but i popped the base off on mine
Posted: Sat Aug 29, 2015 5:13 pm
That's the one Reg, it took me some time to get around to looking at it. I've had the bases off of these before too but I had one where half of the spread rivet split off, so no chance of that happening here
Posted: Sat Aug 29, 2015 5:18 pm
fair enough
Posted: Mon Aug 31, 2015 12:57 am
by mrmoko
Good work . Very nice two line now . .
