48a Meteor Sports Boat & Trailer
Posted: Sat Mar 28, 2015 11:52 am
This model turned out to be a whole lot more interesting than I thought it would be!
The NAMC’s “Catalog of all Series Matchbox Models” (second edition) lists a model at variation 48-1a which has MW, c/a and no pin to hold the boat onto the trailer. The listing explicitely states "Not broken off - 1st casting".
AIM's “1-75 Series Regular Wheels” catalogue (second printing, 1983) shows three different trailers. The first type, unlisted by Nick, measures only 1 7/8" long and terminated in a round towing eye rather than in an elongated ellipse with the eye at the end, and has MW and c/a. The second and third-type trailers match Nick's unbraced and braced examples, but the catalogue highlights the existence of an ejector ring on the underside in the middle of the web to the rear of the towing eye, creating the possibility that the braced trailer exists both with and without this ejector ring.
Houghton notes that the trailer exists in both matt and gloss black. This appears to be an early variation and can be found on Nick's variations 3, 5, and 7. Furthermore, Houghton only lists the dark tan hull as the final version (equivalent to Nick's code 12), all others being light tan. Given the fact that the boats can just as easily be switched on this model and on the 48b, perhaps the deck colour variation should be reduced to a footnote?
Stannard does not list any variations not already identified by Nick.
U.K. Matchbox covered the model in volume 7, no. 3 (Aug. '83), p94, but did not identify any new variations. However, Robert Newson discussed the first-type AIM trailer and I will quote him here: "An early version of the trailer has been reported in several catalogues and the apparently does not terminate in a "spade end" where the hole for towing is cast, but as a circular plate through which the towing hole is cast. As this circular plate is only the diameter of the width of the "spade end", the net result is a carrier some 3mm less in length than the normal. As this early version has neither been seen by the author nor associates, it has not been detailed as such here - can anyone confirm it's existence as having been obtained from a retail shop or is this a pre-production or similar type that was once recorded in a far distant catalogue and has been perpetuated as an error ever since in 1-75 catalogues?" No confirmation was included in the article follow-up published in volume 7, no. 4 (Oct. '83), p125.
Can anyone confirm the existence of the short trailer? If so, does it have the boat locating pin? (I would suggest the pinless NAMC variation is probably a defective casting since, it it were the very first trailer casting, it would be reasonable to assume that it would be the short trailer and it is unlikely that the cataloguer would spot a missing pin but not notice the different towing eye design.) Does anyone have a braced trailer without the ejector ring?
